no spark. WHAT DO I DO NOW?
its a husky 2002 tc570 4stroke
bike stopped dead.
3rd gear giving it a little it just shut off.
like the kill switch was put on
cant start it
tried to kick it a few times nothing
cleaned the carb
put a little petrol in the barrel
new spark plug
NOT EVEN A COUGH
cant get anything from it
the petrol isnt blocked its getting in
so its the electrics somewhere
any clues
someone said it might be the magneto but it was done just before i bught the bike. so 3rides ago
couldnt go that quick
so what do i do now
any tests or trails
want this bike going
you visibly confirmed lack of spark on a new plug? Start checking for loose wires
bypass the kill switch???
x 2 - just unplug it?
Id go back to the flywheel and stator then. Maybe an ohms test on the stator? Maybe a sheared woodruff?
by passed the kill switch still nothing
could it be the stator again?
hasnt took much abuse
Have you confirmed that there is actually no spark by looking at the plug outside the cylinder, laying on the motor?
Trace it back. Bad plug wire, bad coil, bad connection to the cdi, bad cdi, bad pick-up coil, bad stator.
Plug wires, coils, pick-up and stator can all be checked by a multimeter. Cdi is best checked by a switch with a known good one.
Hi,
I don't have the spec's fopr the later bikes,
but If you do a search for 350/410/610 ignitions there are LOTs of good pointers,
I would be tempted to remove the flywheel cover and tank, then get an assistant to help kickstart it / watch ,in a darkened area, looking for arcing from any chafed wires,
with only a few rides after a rebuild you may find something was badly routed,
check around headstock also.., common rubbing point,
all the best,
Charlie
Swap in a different spark plug cap.
Some huskys have lousy caps
