is my stabilized busted?
My scotts stabilizer dial comes to a stop at the end point clockwise and counterclockwise. I just bought a used bike with a scotts stabilizer that will keep rotating. Is it an older model or does it need repair.
Why not send it in to be serviced and then you'll have the peace of mind that all is well.
http://www.scottsperformance.com/dampparts.php
Needs a new base valve:
8 4003-01 Base valve (needle, seat & o-ring) (Dirt Bike)(1) $29.95
To get to my base valve I had to drill out the pin in the knob, so you have to replace the knob:
4 4016-01 Knob with pin(1) $12.95
Then you need oil for the oil change:
http://www.scottsperformance.com/groupitem.php?Item=1527&Groups=187
9007-08 Scotts Stabilizer Fluid $5.95
The rebuild process is simple, there is nothing too these stabilizers (moving parts wise), here is some rebuild instructions for the oil change:
http://www.scottsperformance.com/litrack/259.pdf
