What could cause this ?? Need TTer's input
I've done a search but no common threads.
Here's the problem....my front forks will be perfect on a ride and then all of the sudden they will get real stiff (could be early or could be late in a ride) for a while and then go back to perfect.
I had them serviced and revalved a few months ago ...and I have checked to make sure they are not binding. I always bleed them after I ride as well.
I'm scratching my head ..and bummed because the suspension is perfect and then it gets very stiff (usually at just the wrong time)
any clues ??
post your problem in the suspension forum. Sounds wierd, you may have better luck in there
debris in the oil..... small debris is capable of plugging small orifices and creating havoc... Just a though. Clean your forks and install new fluid and see if it helps....
