idle stays high after throttle let off
When I rev the bike the rpm's stay high, even though the throttle is back to the neutral position. can't figure it out. I popped off the throttle from the bars and cleaned, with no change. is the problem in the cable or the carb?
Confirm the cables have free play (remove the cover on the side of the carb, slightly turn the throttle back and forth, ensure you can see the inner cables slightly wiggling before the throttle wheel starts to move.
If that is ok, replace the pilot jet.
