just rebuilt bike now i hear rattling and it dies
05 crf 250r just put new in valves and new piston.Rode for about 5 hours and at the end it just died. Then i was ables to start it and heard a rattling sound kind of like a ratting chain it sounded like. I took of the head cover and the cam chain seems tight and the valve clearance were good. what could this be? the oil was still the same level. it was hardto kick through sometimes and sometimes it wasnt. it almost seems as though sometimes it was scraping whent i tried to kick it like maybe it was the rings. Can anyone give me some input of what you think before i go into it and have to buty new gaskets? it will still start but makes that noise and then shut off after a minute or so
also it actually wasnt me riding this one.I was riding my 06 and my friend that was supposed to be buying the 05 rode the 05 for the first time he is the one that put 5 hours on it and he said before we went riding he was going to buy it for sure so i said it was his. But i told him im still keeping at my house until he gives me the cash.Anyway i asking if you guys thing he should pay for the damage or me. im going to do the work for him tho. So what do you guys think. hes uses to 2 stroke and he kept killing it because he wasnt in the right gear in the trails and stuff like that. we rode in the trails and it over heated to i nhad to keep stopping for him because he was going so slow. so i think thats why it over heated i dont know. but who should pay for the problem?
Edited by specialkcrf
Did you look at the decompression pin spring? Also, pull the oil filter and see if it has any metal in it. Hopefully the spring is broke.
i just checked that and its good it doesnt seem very strong but neither did the one on my 06
amd just checked oil filter and there were metal shavings lots of them they look like copper but i did change the oil when i did the rebuild but not the filter i no it was stupid
oh yeah, thats the crank. time to split the cases and replace it or rebuild it.
Your bottom end is gone or going. that is shavings from the crank bearings. do not try and start your bike anymore it will only do further damage.
so the bearing will make the bike die? this sucks man i just put in new valves and a new piston . what all am i going to have to replace? should i make him replace this stuff?are those shavings only from the crank bearings?
nice! yep lost the crank, at least it didnt come apart on you and cause even more damage.. time to invest in a crank, main bearings/seal, and prob oil pump while your at it
hopefully none of the metal got between ur piston and cyl.. your going to have to split the case to find out everything you need
How many total hours on that motor?
I doubt your friend did anything to cause that riding in too high a gear on trails....
You know how boats are holes in the water that you throw money into? Well that's what motocross R bikes are on land...
just curious why an oil pump.Because im in there?
not sure how many hours bought it for 1500 from some1 i didnt know and it didnt run put in new piston and in valves and started first kick
do i just need the connecting rod or the complete crank shaft assembly are there kits that have eve thing i need any advice on brands and where to buy them?
sometimes when metal is in the oil the oil pump rotor clearances can be outta spec..
you can choose between a new assembly or if the crank isnt damaged beyond repair you can send it in and get it rebuilt and trued, i find that most guys like stock cranks the most, Charlie has tried a few different cranks so he may be the better choice to answer this question.. a used crank thats rebuilt trues better then a new crank because of all the heat cycles..
I used the stock crank assembly and the pro-x bearing and rod with a lot of success. I did have one fail prematurly and the guy that did the work wouldn't stand behind it after I sent him a ton of work. I prefer that method, but my second choice it the Wiseco assembly. I've used the Hot Rod assembly a few times with pretty decent results, but they were in bikes that weren't ridden very hard at all. My kid and a few of his friends are a real test to these different manufactures. I just installed a Hot Rod in my kids bike a few months back. It has roughly 20 hours on it right now, so time will tell. Be smart about this rebuild and replace any of the bearings that don't feel smooth and do replace the main bearings and seals regardless. The brass you see in the filter is the thrust washers that ride on both sides of the connecting rod the keep the lower bearing in place. It's really important to get that out of the engine and you'll find it in places you wouldn't believe. Do check the oil pump. The bad part is the metal that's roaming around the engine when the crank fails usually grooves the case where the pump rides. I might have a fix for those groves, but I don't know for sure until the crank I put in is goes bad. I tried something different that may have actually worked to restore the oil pressure.
my book says i can slit the cases with a rubber mallet so i woulnt have to buy a case splitter.is that going to work. and do i have to buy a crank puller in my book its also just showing i can just pull the crank out and just put it back in it didnt show any special tools for that. And there wasnt a spec to torque the crank case bolts either. it just said tighten them securely? shouldnt there be a spec tohave them torqued down?
I just rebuilt my sons 08 bottom end less than two hours ago on the bike. You don't need a case splitter or crank puller. A few taps with a rubber mallet around the the case does the trick and the crank will pull right out. Keep an eye on all the washers. Be careful tightening the case bolts, I was unfortunate enough to snap one off, not fun...had to get a welder to tig weld it to build it up and tack another bolt to back it out. Get them snug and a 1/4 turn should suffice. If you feel better torquing them down I am sure 5 to 7 ft lbs would be all you need. Are you going to re-use the current top end gaskets?
well if i could reuse them but im not sure if thtas a good idea.the gaskets do only have like 5 hours on them. thanks for all the info.
  • Similar Content
    • By Callum Hunter
      I'm quite new to the moto scene and I've got a '09 CRF250R in need of what I believe is a top end rebuild. I've never gotten a rebuild before so I'm unfamiliar with the process and the steps to take in getting this done in a safe and efficient manner. I was wondering if anyone knew of any reputable shops in or near Vancouver, Canada (where I live) that could look at my bike and help me out with my situation. About 6 months ago I got an inspection on the bike and the shop told me that my cam bearings had "spun in their journals", requiring the installation of a new cam along with the rebuild. I haven't had anything done to the bike since the inspection so the motor is still in this state. She's running but I'm afraid that the motor is a ticking time bomb and would like a shop to take a look at it, let me know what needs to be replaced and get the rebuild done without me worrying about getting taken advantage of. I'm currently out of the country in school but have plans to get this done once I'm back. Any tips, recommendations, or help would be greatly appreciated!
    • By Kadensmith44
      I’m wanting to powder coat my bike but it’s all new to me. I’ve got a powder coater picked out that I’ve heard is good for what I’m doing. I’m not 100% what kind of sand blaster I need and what kind of media. I have also heard you can’t cook in the oven after you’ve baked your parts is that true?
    • By luke8500
      Hi all,
      I have a 2004 honda crf250r and it wont start hot at all. The motor was just rebuilt with a new cylinder and piston. The valves were just adjusted. It will start cold in 1 or 2 kicks with choke but as soon as it gets hot it wont start. If you bump start it the motor will just turn over without starting.  sometimes it will start. It runs great until you shut it off.  im thinking its either a fuel issue or an electrical issue. Any help would be greatly appreciated.
    • By SandSoldier
      Hello! This listing is for my 2007 Honda CRF250R dirt bike. Last winter I spun the rod bearing and just recently finished rebuilding it. Selling to fund new bike. I am currently the second owner.
      Current registration valid until 2020, pink slip in hand.
      Fresh parts:
      -top end kit: Wiseco; forged, moly skirt coated, 12.9:1 comp ratio (new wrist pin, gaskets, etc)
      -cylinder: new OEM
      -bottom end kit: Wiseco; (new bearings, seals, etc)
      -oil pump: new OEM
      -head studs & nuts: new OEM
      -fresh oil and filter
      -all tolerances checked in top end
      -valves adjusted
      -carb adjusted
      Note:
      *rebuild was done by my dad (master tech at CAT) and I (4th year mechanical engineering student)
      *has maybe 15 minutes on new parts, IT HAS NOT BEEN PROPERLY BROKEN IN YET
      *I have email receipts, pics of rebuild, and old parts as proof of rebuild, just ask and I'll show em off
      Other parts:
      -90% tread on front and rear tires
      -excell takasago front wheel
      -custom aluminum skid plate
      -wrap around hand guards
      -spark arrestor
      -kickstand
      Feel free to ask for any more specifics or pictures!
      LOCAL PICK UP ONLY
      Thanks!
    • By Matt Ray
      Okay so the title is a little vague.
      So it was having trouble idling and even starting when I first bought it about a month ago for $2k.
      So I did a rough clean of carb, looked up on YouTube, Forums, Etc on how to do it. I only cleaned jets with carb cleaner and sprayed around the float bowl area and such, so not too extensive.
      Did that and I took it out to a park, It would start up right away mostly, few kicks sometimes, but when I got it started, I had to keep the choke on. Right when I was ready to go fast and go up to 3rd and 4th gear I'd switch it off and it would work fine and sound fine and everything, but when I slowed back down and coasted around 1st gear i'd pop it back out again because it sounded like it was going to do. I have some videos if people would like me to link to them.
      So after that I decided to take it apart and replace spark plug with OEM NGK R0409B-8, replace main jet from a old 170 to a new 170, replaced pilot jet from a old 40 to a new 42, and kept starter jet the same just made sure that wasn't clogged, ordered a new adjustable fuel screw and used that.
      and it was still having a little bit of problems! I just started up today and the day before today. It would run only with choke on, if i twisted throttle in neutral it sounded pretty good, no gun shot noises or anything, pretty smooth.
      If I tried to take choke off it would die immediately. So I started it back up again, took around 6 kicks.. So again with choke on it sounded like it was starting to lose power and RPM's would drop so I'd twist throttle a few times and it would stay idling.. then after a small amount of time, start to sound like its about to die again... so I would rev it up again, and repeat..
      Fuel line isn't clogged, flows fine.
      I tried fuel screw everywhere between 1 and 2 turns out..
      I checked valve clearances, and I'm no expert but from the videos I watched the slipped underneath intake and exhaust with only minor force.
      So I'm lost..
      Maybe float bowl is messed up? Should I just do a COMPLETE carb rebuild from videos I've seen on youtube, like this one -> https://www.youtube.com/watch?v=3AXb9UprT30? Or what?
      It's getting annoying taking it apart all the time, I jsut want it to start up quickly and run well!!
      Thank you!
      Austin, TX, Elevation 600ft, where I ride its around 900ft
