Exhaust
If anyine is interested or needs a muffler from a 250f i have one im trying to get rid of for $50. Pm me! also what are some cheap alternatives to grip glue?
i use epoxy.the kind you mix the base with the hardner works the best. $5 at homedepot, lowes ace ext.
i'll try the paint next time and see if it works better
What am I the only one the still wire ties them? Well I do put in some of the Pro Taper grip glue though.
You spray the inside of the grips. What I do is strip the bars of any glue, put hot soapy water inside the grips, one at a time, then spray any color spray paint into them. I then slide them all the way on the bar and hold them in place for a minute or two, until dry. They will then stay put.
