08 exc oil transfer Any help?
I have asked a few sources that I have found quite reliable on this site but my transfer is not the same as others. So I am hopping someone has heard of a solution for what I can do. My transfer from is not from the transmission to the engine like most everyone elses. Mine is from the engine to transmission and it only takes about 30 miles to transfer completely. I saw the diy on ktmtalk about replacing the sealant in the crankcase to fix the transmission to engine, but have yet to find a solution for the other way around. So if anyone knows how to fix this problem I would greatly appreciate it. If nothing is posted up about it I will contact some ktm dealers and hopefully they will be kind enough to talk to me on the phone instead of telling me to bring it in. Thanks in advance
Could your failing seal be installed backwards from the factory?
