05 250 fork oil height
anyone have a manual on hand and can tell me the recomended outer chamber fork oil amount. have everything apart now, will be picking up the seals and oil tomorrow.
2005 Manual Says
KX250-R1 = 300 mL (10.14 US ounces)
KX250R6F = 310 mL (10.48 US ounces)
I believe the KX250R6F is the European Model. You probably have the KX250-R1. This is the amount of oil that goes in the outer fork leg. The HP 5wt Pro-Honda fork oil, the pink stuff, works pretty good from my experience.
THE R6F is the 06 and the R1 is the 05. What is cool is that 1 quart is perfect for filling the inner and outer chamber of both forks exactly.
ah ok perfect so i only need one, i have two on order. i got 10 weight though, is it going to be to thick? i always ran 5 wt in my rm 144, but i figured the 250 required 10wt.
