2000 610 tc timing chain tensioner modification
hi all ive seen somewhere on this forum some time ago a mod for the 2000 ish 610 timing chane tensioner. mine is going AGAIN and at £50 each for the tensioner and £105 for the chain you could get a bit sick of throwing your money away
so if anyone knows of a modification to the tensioner please let me know
Hi,
is it the TC or the e-start 610?,
as they use different tensioners.
I toyed with using the DRZ style "aftermarket - fixed" tensioner,
which basically replicated all the conventional " rod and locknut "tensioners.
I had several "USED" husky auto tensioners - funnily enough after 16,000 miles
and was going to adapt one to the manually adjusted "rod and locknut" type.
but then the 2006 revised TE came out and I wanted to try the new-model tensioner ..., but it uses different mounts.
there are still many rumbles about the oil-damping pushing the camchain at prolonged high RPM's - similar to DRZ's.
I ended up trading the bike for a jap 4, as its 100MPH =7,500 RPM was the same as the husky but only halfway around the rev-counter...
I don't know if the internals of the revised 2006 tensioner are all preload spring and added oil damping,
or whether there has been a move away from the oil damping.
George Erl is convinced that incorrect oil viscosity doesn't help cam chain life,
I'm afraid I'd given up by the time I read that info..,
good luck,
Charlie
