linkage swap cr250 to crf250x
I am going to re-shim my 2005 cr250 suspension (front & rear) to match the shims stacks found in the crf250x to make the bike more trail compliant.
Any opinions on whether I need to also install a crf250x linkage to get the full effect of the offroad suspension?
When you are going to swap the lingage you need to make some radical changes to shock settings. I haven't tested this but when you compare crf and crfx stacks, they are totally different...crfx stacks are much stiffer.
You have nothing to loose when you try the swap.
Jusa
Edited by Jusa
