2005 yz 250 pipe question
Are the 04 and 05 pipes different? I am buying a 05 and would like a extra pipe I found a 04 pipe for a good deal..... also what is the stock fork spring size.
Thanks for your help
o4 pipe is the same. you can actually fit a 99-10 on your 05.
Are you sure about that? the engine and frame were totally different for 05...
besides the info that is in the link someone else posted above... starting in 05 the pipes curve around the frame area was different to help clear the slightly larger aluminum frame.
The 05 and later pipes bolt onto 04 and earlier bikes perfectly, and alot of people have noticed better power on their 04 and earlier bikes with a 05 and later pipe. But when bolting a 04 and earlier pipe on a 05 or up bike you gotta check to make sure it doesnt bump the frame.
the engines were pretty much the same thing and has been the same thing since 02 i believe
Sorry, I didn't read correctly, I thought he said it was a 125.
Yeah, the 250 engine is basically the same.
