headlight & taillight
ive seen some 250x's on here without the headlight or taillight and was wondering where you guys got them from. is it hard to disconnect the lights and replace them? thanks in advanced
the lights simply unplug. you can put a 250r # plate on and a 250r Rear fender.
So you're saying all I need is a new "R" number plate? You know this, or are just pretty sure? Is it really that simple?
Because I don't like the front light look, and I don't honestly see it being enough light for squat.
The R plate fits with modification. Cyrca stadium plate works perfectly. Installs with three zip ties. As mentioned already the headlight just unplugs. Be sure to tape up the unused plug to keep water out. Cyrca also makes a replacement rear fender without the light.
250 R rear fender bolts right up. +1 on the cycra stadium plate. lights like mentioned above just unplug
Yep the 250r front number plate and the rear fender work perfect!:banana:
The only problem that I ran into was that the cast mounting hole in the front hits the number plate, but when iis on there you cant even tell:smirk:
