Just bought my wife an 07 WR250
Ladies
If any of you ride the WR250 i would like some suggestions of mods that you have done to make it easier for her to ride. We are mountain and desert trail riders.
This is a list of what i have already done:
Rekluse clutch
Protaper Bars and riser
FMF Pipe
Cycra Hand Guards
AIS Removal Kit
JD Jet Kit
Thanks for your help!!
Marc
I love mine!
here are my mods
stock yzf pipe and silencer
rejetted--main jet: 182
needle jet: stock 2002 yz250f in 3rd position OBEKP
leak jet: 40
Thumpertalk smog removal kit
Throttle stop ground off from 32mm(stock wr) to 27mm(stock yzf)
Removed snorkle from airbox
grey wire disconnected
Yamalink lowering link
stuff about the Yamalink
http://plushpuppymx.blogspot.com/2010/02/yamalink-review.html
hope she loves the bike as much as I do!
PS, doing deadlifts with 100# makes it easy to pick the bike up too.
My next bling will be UNibiker radiator guards
PPS, I ride at 1000-4000 feet, the jetting is a little rich, and now I'm faster on the throttle etc so it bogs a bit with that, I think hub will be changing it. My bike bump starts tho super easy so the rottle whapping bog is easy to deal with(unless I'm trying to pass my kids grrrr)
How much does the Yamalink lower the bike? Does that interfere with suspension (softness/stiffness)?
Thanks!
Thanks!
my lowering numbers are in the link I provided. You reset the sag after putting it on, and no it doesn't interfere with travel or how your suspension works. You do need to have the right springs for your weight and riding style(say if you are really aggressive then you can get away with stiffer springs). The bike is stock sprung for about 160-170#.
I have a Yamalink from my '05 that I need to get rid of. You can check with Yamalink if it'll work on your '07. Let me know if you're interested.
