Ring Installation
What is the proper sequence to install the rings so that it is easy to get the last one in?
Thanks
Put on the wavy oil scraper ring first. This will stretch its diameter a bit, decreasing its height and letting the flat rings fit alongside it in the piston groove. Then put on the bottom flat oil scraper ring, followed by the top flat oil scraper ring. At last put on the top piston ring and you're ready for assembly.
