dr350 valve gap
what is the proper way to set the valve clearances on my dr350s?
I am going to take the stator cover off to find tdc because right now my head cover is off.
I tried opening the access port in the stator cover and it wouldn't budge.
You can see TDC with the top covers off easily. The cam lobes at TDC will be pointing downward (front and rear). Another way is to use the kickstart or pushing the bike slowly in gear until you feel compression. TDC is just past that point.
