Cr250 Front fork diameter
I am currently converting by 1992 to 1996, i must get a new triple tree to do this and i need to know if the 1992 forks(5.7cm) will fit in the triple tree. If any of you have a 1996 cr250, could you please measure the outer diameter of your fork for the measurement, thank you.
www.racetech.com
you can find the specs of the forks like 43mm vs 45 vs 46mm. it will list the differences there if you go back and choose a different year. basically if the forks are different sized you need the corresponding top and bottom clamps.
