Yet another please confirm my jetting thread
Hi Guys,
I did a bunch of research on here and here is what I cam up with:
My Bike:
2002 DRZ400S
400E FCR carb
400E airbox
400E cams
Yoshi TRC full Titanium exhaust
I will be riding between 2000-4000' elevation.
Carb settings:
160 Main Jet
200 Main Air Jet
EMN Needle 3rd clip position
45 Pilot Jet or 48?
100 Pilot Air Jet w/ coast enhancer removed or 60 with CE intact
2 turns on fuel screw will get the Keintech or Zip Ty, which one is better?
I will also be doing the Eddie Mod
A couple things I'm not sure about is the pilot and the coast enhancer. If it works, I would like to keep it. What's the opinion about this?
Also do I really need to order a jet kit or can I just get the jets I need?
Thanks Everyone!
Edited by notslow
i would do more like-
155 main jet
200 main air jet
EMP needle
clip 3
45 pilot jet
2.25 turns fuel screw
dont buy the zip ty screw.
as for the CE,its up to you. i see them more and more these days not functioning correctly.
Thanks for the info Eddie, you're the man.
Is the Keintech screw okay?
Does removing the CE have any negative effect?
I've had the Zip-Ty for over 10k. Seems ok. :banana: I remember there was some concern about it damaging the FCR, but then no worries.
any screw that isnt aluminum is fine.
if you remove the CE you may notice a little more pop on decel.
I was thinking aluminum seemed fragile for how tiny the tip is.
Anyone try the TM Designworks Titanium fuel screw? Will it fit the 400E slant body FCR?
The Stealth Racing fuel screw looks cool too, anyone use it?
Edited by notslow
Sorry to jump in but I just bought an 03 E with 3x3 and full exhaust and would like to know if the jet settings here are good for 600-900 feet elev. as well. I am currently running 160 main, 200 main air, stock needle on 5th clip. I think 48 Pilot and coast deleted. Not sure Does this sound right?
