KDX200 piston life
Ridiculously long. Like inspect piston/rings every 1,000 miles. No recommendation on replacement other than replace when wear specs are exceeded.
They don't give a recommended interval that I've ever seen. Just when the compression starts dropping much, order a piston and gaskets.
Don't see what year KDX you have, but '96 and up, usable compression is listed as 95-151psi. Gets down around 120psi, I'd start thinking about doing the top end.
