what happen to my DRZ400 it just quit!
I was riding my 2003 DRZ 400 on a mountain road when it just quit. It was as if someone reach up and turned the ignition off. When the bike came to a stop, I tried the starter button. The starter will spin but will not turn the engine. When I tried to compression start the bike it was as if it was not in gear. If you pull the bike backwards you get compression. What happen to my bike?
Start by checking cam timing and valve clearances.
Mine did that and it was a bad spark plug. Before you go nuts ripping it a part, check the simple stuff, gas, spark, air....
your discription reads almost the same as my
engine dieing........
Primary nut backed off..
pull the valve cover, check timing/cam position.
rotate crank by hand, confirm cams rotate.
sorry to say, you tagged the valves
