oxygenated fuel
Whats the deal here with oxygenated race fuel.
THey are claiming that you get more power when you use oxygenated fuel. I suppose this could make sense if somehow oxygen was added to the gas and you upped your jetting to accomidate for it. But the oxygen would displace the fuel per volume anyways right, making it the same anyways?
Whats the deal?????
Thanks
There is oxygen in oxygenated fuel.
Oxygenated fuel can make more power if you set up the motor for it. You have to jet richer.
its also pointless to run it in a stock motor. it does add power to the higher comp piston, cam setup. a cpl pts higher on the main is all thats needed. vp u4.2
