Tachometer don't work
Ya don't work, never did since I got the bike.
The gauge mounts were broken so I am JB welding them as we speak.
Tach, wires stc.. look Ok at the Gauge.
Anything I should check ?
Thanks
Tachometer? What's a tachometer? Isn't that something that comes on most bikes other than DR650's?
you mean to say there are bikes other than DR650's?
A tachometer (also called a revolution-counter, rev-counter, or RPM gauge) is an instrument that measures the rotation speed of a shaft or disk, as in a motor or other machine. The device usually displays the revolutions per minute (RPM) on a calibrated analogue dial, but digital displays are increasingly common. The term comes from Greek Ταχος, tachos, "speed", and metron, "to measure".
Dr-650 : An under powered cumbersome gas powered street motorcycle disguised as a dual sport motorcycle. Usually driven as a Organ extension
by persons born with an extremely small one.
Well Wikipedia said it, Did I mention I ride the nimble
extremely off road capable (drivin by well equipped men)
DR-350 ?
Dr-650 : An under powered cumbersome gas powered street motorcycle disguised as a dual sport motorcycle. Usually driven as a Organ extension by persons born with an extremely small one.
underpowered? maybe. underpowered compared to a DR350? Not by Suzuki's numbers. But your 6 speed trans definitely helps some.
1991 DR350S
260 lbs dry
30 hp
8.7 lbs per hp
1991 DR650S
335 lbs dry
46 hp
7.3 lbs per hp
75 lbs lighter off road is a huge difference but my 5.5gal fuel tank will take me much further off road and back than your 2.4 gal tank.
_
I do kind of miss having the tach on my DR650. IMHO the instrument cluster on the DR2/350s and early DR650s was much nicer than what the 650's come with now. I also really miss that 6 speed gear box but I sure love the power and torque that my 650 puts out!
Ya well my 350 has an over sized tank.
but seriuously my last bike was a 150hp 1000cc so every thing since then feels pritty gutless. but the 350 is pritty capable off road as I'm sure the 650 is.
Any answers to my original question ?
1991 DR350S
260 lbs dry
30 hp
8.7 lbs per hp
1991 DR650S
335 lbs dry
46 hp
7.3 lbs per hp
Does anyone know if you can feel a huge difference in power between the dr350 and the dr650? I like the torque of my 06 dr650 but have thought of purchasing a dr350 to add to the stable but not sure if I will like it or not.
