2010 KTM 450 EXC - Rekluse - Yes or No?
Getting the new 2010 KTM 450 EXC Califonia Plated machine :banana:
Doing a few upgrades. Considering a Rekluse clutch.....................
What to do? I have only rode a bike with a Rekluse maybe 10 miles. Is it worth the money? I get the feeling it is something you have to get used to.
Input from the peanut gallery is appreciated. :lol:
08 KTM 450 XCRW. Rode it for over a year w/o my current Rekluse Pro. Need it? Not necessarily. But, it comes in handy in some conditions (paddlin' through mud, rock gardens, etc... We have the same motor, it does not stall easy and the clutch action is quite good. For Dual sport, it's nice to sit at a light in gear without having the clutch pulled it. If you get the Pro model, you can clutch just like normal if you feel the need, so it's not something that takes much getting used to IMHO. If the pocketbook allows, I don't see any real downside and a few nice upsides, depending upon where you ride.
my thoughts too, run one on my yz and it cuts down on shifting from 3rd to 2nd alot, also if you misjudge and are a gear high then just hit the gas. hope to install one on the 450exc, the bike has too much power for tight single track and hopefully it will tame it down.
Bryan hit it spot on regarding the clutch action. I was going to buy one for my new KTM and after riding it for awhile decided I didn't need one, even racing EX on a ski resort... the bike engine characteristics with a smooth easy clutch makes it easy on the arms.
In ultra tight trails, I could see the need for one...
I drank the orange coolaid a little over two years ago with the 08 450 EXC. And today I drank the Rekluse coolaid. Time will tell if I become a convert and love it like the rest of you. :banana:
I never rode with one but someone brought up a good point I never thought off. He was on an off camber steep switch back once and the bike would just keep rolling when stalled. He said after he almost tumbled down a cliff he promptly got rid off it
Good point, I never thought of that one. I just bought the Pro model and hope to get it installed this weekend. I've heard so many good things about these clutches but losing the lock up when the engine stalls can be an issue on steep hills/rock gardens. Thanks for the heads up.
I just bought a bike with a rekluse and LHRB. I am up in the air about it. I live in a land of step-ups (Moab) so my carb has to be perfect. I miss the get yourself out of trouble clutch and rev. I think the pro would be killer best of both worlds. I'm going to give it a few months to get used to, I'm worried about pulling the brake when I want power though. If you just give a bit of gas you can get the clutch to catch easily, I was worried about this the most.
This scenario illustrates one of many situations where the LHRB proves to be indispensable for use with the auto clutch.
But, would the bike have stalled to begin with?
The fact that the auto clutch engine was stalled or not is really immaterial since the engine is always basically in neutral when the bike is moving slowly or stopped.
In neutral when moving slowly? Not in my experience. I guess it must be how I ride. My point was, how'd he stall the bike out to being w/ with an autoclutch? I know it's possible, but in my use, it doesn't happen very often at all. Essentially to the point of not something to worry about IMHO.
I guess it all depends if the person stalling has actually fine tuned the engagement. I tested mine over the course of about 4 hours. Took it apart about 5 times until I got it perfect. I tested the manual clutch repeatedly under different situations,to find out where I was revving with the manual clutch(which turned out to be approx. 2200rpm) When I finally got the REKLUSE right it was engaging at about 2100-2200 rpm. Perfect for bush use and not a worry about stalling out, almost ever. Most of the times when it stalls out will be associated with a bad decision on my part picking the wrong line or locking the rear brake at the wrong time.
I think you're spot on.
We have switchbacks here in washingon where you come up to a section of trail simply gives way/ disappears to a solid granit rock with hundreds of feet sheer drop offs. It's up to the rider to interpit where the trail is. I can see someone freezing in a section like that if your scared to death of hights(like me) haha
We have a few trails like that here in Colorado. :banana: :banana: :lol:
or you could always grab the RHFB :banana:
not so, when properly adjusted the auto clutch acts very similar to a conventional clutch at very low speeds. the auto clutch really only comes into play when taking off slowly or accelerating in too high of a gear otherwise rides pretty much the same as a stock clutch. just my opinion. i like the rekluse in the gnarly "get off and walk it" using the engine to propel over rocks/roots or whatever. its nice not to have to work the clutch lever.
I'll stand by my statement. I said that the engine is basically in neutral when the bike is moving slowly or stopped. By moving slowly I mean moving below the clutch engagement RPM. At this speed or when stopped the engine is basically in neutral since the clutch is automatically disengaged. There is not really much to argue about here.
stalling and no bump start and stall on a hill climb are the only two riding issues I had. The issue mechanically I had was that sometimes the timing of being on the gas and locking the rear wheel would be a little off and it would kill the motor going into a corner. With a clutch you just seat bounce and keep going.
The bike WILL stall if you lock up the rear wheel in some cases. I had one on my 200, havent tried it on the 4st with elec start yet.That would help over come the problem of a restart on a hillside for sure.
  • Similar Content
    • By TheLastByte
      Looking for something a little lighter and faster to supplement my xr650l and I think this bike might fit the bill. I'm hoping there are some owners here who can give me some insight into the typical experience with this bike. The question I'm most concerned about is how many hours these engines last before needing a rebuild with normal trail riding? Also, how do they handle in technical terrain? How about on the road?
      The machine I'm looking at has about 75 hours and 1,500 miles on it, all stock other than a lectron carb, and comes with some dualsport lighting not installed. The current owner's asking price seems pretty high at $4500, but he seems to be a communicative, eager seller, which is practically unheard of in Upstate NY where the vast majority of dirtbikes on Craigslist are owned (or "owned") by rednecks trying to flip them. I'm willing to pay a little more than market value for this reason.
      Thanks for any input!
    • By Chad Harlan
      Hi all,
      I got a set of the Axis passenger pegs to fit my 14' 500 exc. The bike does have the alloy sub-frame, but I'm curious if anyone has used this set up with success without destroying the sub-frame or their wife/gf?
      Short trips like errands and rides out to the coast for hiking. 10-15 miles on the longer rides, and likely 0 miles on the highway, as she is not super stoked about riding. But our job kinda doesn't allow multiple vehicles. Yachties. Also shopping a sumo set up at the moment too.
      Thanks folks!!
    • By Bryan Bosch
      Recently,I took a trip out to Colorado for some R&R on a family vacation. I brought my riding gear and had planned on renting a bike, but I was too late and at least what I looked at, there was no availability for my timeline. Bummer, since I'd not ridden the rockies in over 4 years, something pretty special when you live in flatlanderville (Florida)!
      But, behind the scenes, a couple of TT'ers were at work! Through TT, we recently hired a fine, young gentleman to head up our advertising sales team,( @Freemotion ) and he pulled some strings with a local who had a well equipped  KTM 450XC-W that is his back-up machine. His new love is a 2019 KTM 300 TPI and it was gorgeous!
      So, a HUGE thanks to @Freemotion for greasing the skids in getting me a skoot and to @G 9.5 for generously lending out his bike to basically a stranger. The weather was great, so was the company, and the riding was epic as far as I'm concerned. I'm still a bit humbled by the generosity, so I wanted to share a story that I bet isn't as uncommon among the riding community as one might imagine.
      Dirt bike people rock! 🤘
    • By JacksonDRZbeast
      Hello TT peeps. I currently have an 11' Ktm 450 exc which i am converting to sumo. Still on the fence about getting cush drive rims or standard rims. Not too much info on what cush drive does for wheelies. I know its smoother on the tranny and chain but will it make much of a difference with slower wheelies/stunting? I had a DRZ with standard rims and slower wheelies were very choppy and almost impossible to control smoothly. Any advice/tips/help will be much appreciated.
      Also.... will 5" rims be pushing it for chain rub? Should i just stick with 4.25"?
    • By scott72
      Hi, I was wandering if anybody has recently bought or sold a 2014 or 2015 500 exc?  I'm trying to get an idea as to what they worth presently.  Thanks for any help.
