Radiator Sensor Plugs Removal
I don't use the stock fan or the stock temp sensor anymore so is it ok to remove those and replace with a suitable plug? I know that the fan side I can disconnect without worry. The actual temp side comes unplugged by way of two sealed quick disconnects. Will I need to connect these two together like the side stand switch or can they be left alone?
I do not know of anything more suitable than the sensors themselves. If you find something to fit the threads, it should be steel or brass, not aluminum. At lease not bare aluminum.
I never did find and off the shelf plug that fit. I ended up making one. But I only looked locally... Likely could have ordered something from McMaster Carr
Thanks for the reply EM. Im going to continue the search. ill post what I find.
Edited by DRZ400Senior
