Poll: How many have had engine failures / problems?
Please reply with the details
Year: 2000 & 2007
Model: DRZ400Es
Miles: 16,000km and 10,000km
Engine mods: MCCT. stock.
Have you had an Engine Failure ? Y
If yes:
What was the cause? and had it been rebuilt previously?
An inlet valve closed up to zero clearance at 6000km. The motor ate dust (somehow) so it was not the fault of the engine. Inlet valves replaced and ran great.
Brought new in 2002
25 miles battery failier , dealer replaced
1400 miles snapped chain this went back to Suzuki , dealer replaced
15000 miles , stator failier i replaced this with a high output Baha Item.
22000 miles 436 big bore installed Wiseco stainless steel valves new guides
34456 miles still going great.
Then its just output seals clutch arm seal ect ect so overall a very good bike:thumbsup:
i bought my 2nd drz in late 2005. it was a used, non-running, incomplete plated e model with unknown mileage.
by feb. 2006 i had wired up some lights & street legal stuff & put some sm wheels on it. rode it for about 17,000 miles before the crank and/or crank bearing went bad. locked up on the highway coming home from work.
i did have a stator bolt back out(my error) & sent some metal thru the motor approx. 6,000 miles prior the failure, which may have contributed to the failure.
Year: 2007 bought new
Model: DRZ400S
Miles: 6140
Engine mods: stock; 3x3; rejet
Have you had an Engine Failure ? N
'01 E model
Dropped a valve guide, it turned out to be cheaper to buy a used engine for it.
Model: DRZ400SM
Kms: 16,000
Engine Mods: TT FCRmx, Full RS2 exhaust, stg 1 hotcams, MT 450 bb kit, ported head, RHC valves
Have you had an Engine Failure ? Y, First Milenium head had a tweaked sleeve allowing coolant to mix with oil. Milenium replaced free of charge.
Only other issue was speedo was changed under warranty when droplets developped under the lens
Edited by RToth
2001 DRZ 400S
20,000KM
3X3 and jetting
Annual oil changes. Rotilla 15w40
No problems whatsoever.
2005 DRZ SM (new in 09)
6000km;s
MRD/SSW, 3x3, K/N filter, FCR M/X, JD jetting
3 oil changes, working on Loctite fixes
No Problems except not fast enough yet LOL
2004 S (bought used in Aug. 05 with 1990 miles)
All stock except for 41 tooth rear sprocket.
24,2xx miles, sloppy crank bearing allowing stator/rotor contact
valves sill in spec, replaced S engine with E engine
hit deer and totaled bike- Rest In Pieces- 11/1/08
2007SM:bought new in may or 07
12,000miles- commute/track riding since day i bought it.
not one real problem. i had a few fuel problems(caused by smog crap)fixed by desmogging. swapped acct for TT mcct,but still sure there wouldnt be any problems if left alone but did it anyways. starts on first try weather its 20deg. or 100deg. all stock
'00 DRZ-S
JD jetted, full Yosh, 14/47
12k a difficult 12k
NEVER MISSED A BEAT
2005 SM. Bought it Nov of 08.
Speedo died at 1200mi
Speedo died again at 1500mi.
Speedo died again at 2200mi
MRD/SSW pipe, 41mm FCR, Hotcams, 434cc, MCCT
I put about 7k miles on it and it ran great but I did have a bunch of countershaft sprocket seal go. Like 8 of em...
The seal on the shift shaft let go at about 6k.
The starter clutch bolts backed out killing the stator at about 8K
The waterpump seal (at the gasket) let go at boout 10k and put allthe coolant in the oil killing the crank an drod bearings, scuffing the piston...
I bought all new bearings, 5mm stroker crank and 94mm CP piston. Just waiting on a bit more money to order the new valves, springs and cams.
I'm not new to maintaining motorcycles and this has been the most unreliable motorcycle I've ever owned. It's also been the most fun...
Edited by PBMW
2001 DRZ400E
Everything stock
unknown miles/hours.
had one of the four bolts holding the exhaust cam down rattle loose and do some nice vibration damage there.. in the process of renewing motor now.
2005 drz400 SM
fcr39, hotcams, bigbore, yosh ti
13000 km / 8000 mls yesterday
no problems
(at one point it used oil because of an error in installing the base gasket, done by a shop. the bigbore install corrected that)
2003 kicker
Auto decomp pin broke went in engine got wedged between flywheel and stator.Burnt out stator.Rewired stator,removed auto decomp.
Year: 2008 bought new
Model: DRZ400SM
Miles: 6,915
Engine mods: stock, 3x3 and rejet, all TT recommended fixes
Year: 2006
Model: DRZ400SM
Miles: 17,450 miles
Engine mods: None
Have you had an Engine Failure ? Nope!
My recipe for a healthy DRZ? Change the oil & filter every 1000 miles. New tires when the threads show, and a new chain when you gotta tighten it more than twice in a week.
03 E plated , 7k , all of the TT tweeks are done and it runs great still. Oh there was the time at 6.5k that my stupid ass never read all of the loctite fix and the starter clutch bolts ate the stator!
Thanks to "BRONCO" and his support and expert advice it's all good again!
06' E
About 50 hrs a year
cange oils every 3-5 rides
FMF power bomb header
FMF power Q4
FMF jet kit
14/49 gearing
race tech suspension.
many more small mods
never had any engin probs
neck stem bearing went bad
Starts every time and runs great
Will see if it keeps its rep when I switch to the FCR.
maintain, maintain,maintain it will run forever
