what tyre pressure lc4 640 supermoto
what tyre pressure lc4 640 supermoto. Would be helpfull if someone could tell me as i have no hanbook thanks.
Mansy: Tire pressure is a relative thing. There is a difference in tires (compound), ambient and road surface temperatures as well as the amount of thermal energy you are working into them.
I run about 30 PSI (~2.1 BAR) in my 05 625 SMC MT60s under "nominal" conditions. Most tires rarely need more than that.
Nominal here is ~25 deg C / 72 deg F.
If it were warmer and the road surface is hotter, I'd drop them slightly. Personnal preference tolerances are usually within one to two PSI.
