PW50 wiring harness
hi there, i bought a second hand wiring harness,coil,cdi etc attached, i went to plug it into the bike, and i does not fit? MY plug is square where as the second hand plug is small rectangle with a seperate B/R . my old cdi,rev box looks nothing like mine.
i will try get a pic soon but has anybody any idea is they changed them at any point?
they are all pretty much standard for quite a few years. take a pic and i will compare it tonight.
do you think the US / UK harnesses are any different?
so i take it theres no way of chopping and changing it to suit?
THANKS
you can cut up anythign and make it work, but when you start messing with things like that you increase points of failure and make troubleshooting often more difficult.
try and get on a OEM parts finder and see if it has pics or pin outs to see if you can identify a difference.
the only difference i can see is the box where is joins the motor, but all the wire colours etc are the same.
my box had 3 wires W..W/R..B.. and a single B/R
new loom had 2 wires from the joining plug and 2 single wires
hope this makes sence.
