Winter Gas Question
If you left gas in your bikes over the winter, either stabilized or not, do you drain the old gas and put fresh in for your first spring ride or just use up whats in the tank before putting fresh in?
i think this is more preference. depends for me. generally i just ride all the badgas out of mine. but some people would say thats a big no no. i think if you have stabil in it then it should be fine. i would just drain the crap gas out of the carb and start from there. :banana:
I always run the bad gas out. The stuff is too expensive to waste. I add a little Seafoam to the tank before I start up and it will clean most of the junk out of the carbs created from setting with old fuel in them.
2-stroke or 4-stroke?
2-stroke, shake it up real good and go ride.
4-stroke, drain tank and carb, fill with fresh fuel.
