Quick 470 Question for eddie
Running hotcams - with motor together but not in the bike yet - piston to head clearance is 0.050" (1.29mm) does that sound about right, or is it a bit tight for the hotcam setup ?
Thanks
Hi,
Sorry - Your spacer.
JE - piston supplied by yourself (3 ring)
Hotcams 2 - 107 / 104 lobe centers
The gaskets is the problem - from the looks of it the builder seems to have used 1 either side of the spacer.
Hence the reason I took the piston to head clearance to see whether you would be able to tell from that if the comp will be low enough to run pump fuel (95 oct)
too tight for sure especially with those cams.
with that set up you want .060" minimum and preferably .070" to keep it from detonating and pushing head gaskets.
