Antigravity Batteries Product Giveaways - LAST NIGHT TO ENTER! Read more... ×
Couple questions about FMF exhaust system!
I have an 07 KTM 450 SXF and I am looking at buying a new exhaust system for it. What I am looking at getting is an FMF Ti Megabomb header with a Factory 4.1 muffler. I just have a few questions to ask from anyone who has this system or has experience with it.
What are the power gains over stock?
How does the powerband change? (more low end? more of a hit?)
How much louder is it than stock?
Any feedback would be greatly appreciated. Thanks!
Don´t forget to re-jet or you won´t find all the power a pipe is capable to offer.
If you don´t already have a JD kit run ,don´t walk ,to the dealer to get one.
Thanks. I have my mechanic doing it for me, so I'm sure it will be all set up properly.
Any opinion/experiences with this FMF system?
I have this system and have ridden it back to back with the stock setup. There is a big difference especially down low. It is louder than stock, but so is every other system out there. I have the JD kit as well as a big bore, but I also ran the system without that stuff and it was just as good.
I just put on a megabomb header with my race ready kit FMF muffler (which is a Factory 4.1 I believe). I've ridden 2X with it. I haven't touched the jetting although I am running the JD kit. It's been in the low to mid 40s (F) during those rides. Overall, I'm pleased with the change. The pipe seems to let the bike turn over a little faster and it did boost low end power a bit. Nothing earth shattering but, satisfactory. I would say that the difference is not as distinct as it was with my 05 CRF but, I did have a hotter cam, and porting so, that could be the difference. A good thing is that it didn't turn the bike into an arm jurker. After I fit my Honda with the exhaust, that thing had a violent hit, which is all well and good when you're trying to impress your buddies but, it doesn't translate into faster lap times. In my opinion, it didn't seem to rob from the topend pull which is good because that's something I really like about these bikes. I'd say I'm clearing jumps a bit easier with it. As far as the noise goes, I'd definitely say that adding the mega bomb reduced the noise level. BTW, what jetting changes should I be doing with this set up? Fatter main only? I'm at 4500 ft and I run the red needle, 45 pilot and I think the main spec'd is 180. I basically run what JD says to run in their guide.
I have an aftermarket pipe on mine too (Akrapovic) and i also , of course , run the JD jetting but i´m far from the recommended settings. First of all i have the blue needle set at 4th pos. vs. rec. 3th. I also run 195 MJ (you read that right) instead the recommended 185. The more open pipe does increase the flow so going up in the MJ is almost always needed. I would go as far as to claim ALWAYS needed.
I convinced Bassic to try the different needle pos. as well and you can ask him how he felt about it. I don´t know which needle you run on your altitude and in which pos. but i would lower the clip one pos. and try it.
I don´t know what difference it makes in your case but my bike gained a healthy dose of low end /mid-range torque and power with the clip pos. change.
Try it - it doesn´t cost anything ,except little time , and you can always go back if you aren´t satisfied. I would definitely try a bigger MJ in your case as well.
  • Similar Content
    • By Urbanpoacher
      Hello everyone, I am new to the page and to the world of ktm. I recently purchased a used 2008 ktm xcfw with a 300 big bore kit, not sure who made or installed the kit. I am looking to see if there is any way to buy a new carb that is set up for this bike with the 300 BB. Any help would be great. The fuel inlet is leaking and there are a ton of stripped screws so I’m thinking getting a new carb might be the best way to go but i don’t really have the skill or knowledge to tune and jet a stock one myself. Thank you!
    • By christophe19912
      i am currently checking valve clearance on 2013 sxf 250 with 70 hrs. bike was bought new and never been apart(as far as i know). when setting TDC the notch on the crank when it is aligned to the whole, has the cam gear marks intake totally up and exhaust totally down. are these the wrong marks to look at or am i missing something. bike does run just a little difficult to start.
    • By gyodock
      2016 KTM 350xc-f - Olins Fork Cartridge Inserts, FMF 4.1 RCT Muffler, Pro Circuit Linkage Arm, Torc1 Reaction Shift and Rear Brake Lever, P3 Carbon Pipe Guard, Acerbis Skid Guard, Mobie Linkage Guard, Acerbis Swing-arm Guards, RYD Crew Aluminum Handguards, Sicass Racing Tail Light Kit with Flush Mount LED Rear Turn Signals, Sicass Racing Handguards with Built-in LED Turn Signals, Rental Sprockets, Trail-Tech Stator Upgrade, ktmandhusky.com Fuel Rail and Anti-vibration Bar Ends, Guts Seat Cover, USB Charging Port, Misc Anodized Orange Aluminum Bling. My wife is getting jealous of the attention I am giving my bike!
    • By Dandeliongardens
      Hey all. I’m a newbie here so let me know if  I’m in the wrong place.
      I’ll get straight down to it. I’m in the market for a new bike and have been thinking about what’s going to be best for me for a long time. Until recently I finally came to the conclusion that a new YZ250FX is my best option. My last bike was 2015 Yz250f which I loved.
      Now just yesterday I saw a local dealer advertise left over 17’ FX350’s for almost the same price as the YZ. What appeals to me about the Husky is that extra grunt. What doesn’t appeal to me is the suspension and handling and the reliability of the machine. Now I’ve never owned a KTM or Husky so I am basing those two factors on word of mouth only. Like I said, I loved my Yz250f and felt very at home on it, it has probably been the best bike I’ve owned to date. Yamaha reliability is also second to none which adds to my peace of mind on purchasing the YZ. One thing I wish it had was more power though. Obviously it’s only a 250f so you can’t expect it to go like a 450 (not really interested in 450s).
      I ride mostly trails and the occasional day at the mx track. The trails I ride are gravel based, loose, rocky, single trail, and also wide, fast, flowing, sand trails which is where I think my yz250f really shined, and where I had the most fun. I’m only a small rider at 145lbs which is why I’ve steered away from 450s.
      I’ve read a few forums and others have said the ktm and Husky 350s are unbeatable on the trail which is why I am in this dilemma.
      So basically what I’m trying to decide on is if that extra power is worth compromising for the YZ suspension, handling and usability. Feel free to make any other suggestions, including other bikes as I was also considering the YZ250X 2T.
      Thanks guys
    • By element9
      The story begins with simple installation procedure of a BIG BORE kit that we ordered from USA . The manufacturer (CYLINDER WORKS) and the dealer send us the correct kit and so far so good ! .
      The bike is a KTM 250 sx-f ,2011 model and bellow there are some photos for you, just to see how careful I am throughout the process .
      .. .. .. .. I change the valve seals and the exhaust titanium valves and springs with the PROX steel kit and make a little polishing on the intake and exhaust
      Put the cylinder-piston on and always with guidance from workshop manual and correct clamps...
      AND READY
      Until now we where happy !!! We start the engine ,and everything seems to be ok!
      Began to make the first ride and…… DISASTER !!!
      The engine start bleeding OIL from the hose-tube !!!!!!!!! I thought its normal if it is one-two drops but unfortunately didn’t STOP .
      We did one more ride to see what happens and still BLEEDING. Back to the WORKSHOP.
      DO YOU HAVE ANY SUGGESTIONS OF WHAT TO CHECK OR DO ???
