1997 Kick Start Oil Seal
The oil seal on my kick-start is leaking a little bit. Do I have to pull the side of the case off to replace it or can it be done from the outside?
You should be able to replace it by removing only the kick starter. Be sure to wrap the splines of the kick start shaft with electrical tape before you slide the new seal on to avoid damaging the seal.
