Skid plate mounts on 2008 YZ 250f
One of the nuts that are used to attach the skid plate has pulled through the aluminum mount on the front of the frame. Has anyone had this happen, how did you fix it?
Use a helicoil kit or tap it and use a larger bolt.
The thing to remember on those bolts is that they are tight with 10Nm of Torque. That's only 7 ft lbs, not a lot of pressure if you're used to working on cars or your motorcycle's axle bolts.
