XR600R pilot screw o-ring and washer question
So in giving my new 88 600 the once over I pulled the carb. It looked really good and still had the stock jetting of 165 main and 60 pilot although the needle was in the 4th from the top position. I stuck in a 65 pilot and moved the needle back to the middle. Anyway, my question is that the airscrew was missing both the rubber o-ring and the washer. My question is has anyone found suitable replacements other than from Honda. It seems as if I would need to buy a carb gasket kit to get the rubber ring and then a new needle to get the washer to the tune of 35 dollars for these two little parts. Any ideas or help much appreciated.
Bill
