05 rm 250 with rattles? can it be a power valve
How high pitched is the rattle? After I took my pipe off a couple times the springs lost enough tension that they would rattle pretty loudly at certain RPMs. I thought my engine was falling apart until I realized what it was.
And make sure you didn't leave a 10mm wrench in the airbox, not that I would know what that sounds like :banana:
Does the pipe fit snug in the cylinder? If the o-ring wears out and lets the pipe wiggle a bit I'd imagine it could make a bit of noise.
My pipe wiggles a bit and squirts out oil on the pipe from the cylinder. is there an oring there i should replace? new to 2 strokes
