2005 rm-z 250
ok so my best friend has a 2005 RM-Z 250. he blew it up back in August and he got it back. the people he took it too only replaced the piston rings? they said the rings and the jug were bad. and so he got it back and he was on a burm and dumped it. and it hasnt started ever since. any suggestions on what could have happened? we are all stumped :banana:
You might have just gotten lucky when he started it the first time. Make sure that the carb is clean and adjusted correctly. If it still doesn't start then try doing a compression check and then check the cam timing.
the carb is cleaned hardcore and the jetting is correct. not sure about the timing or compression tho...
