08 wr 250r
A friend of mine has this bike but she can barely reach the clutch lever (small hands), anyone know who sells levers closer to the bars?
My girlfriend had the same issue with her quad. I bought another cheap aftermarket one and had a buddy of mine take it to work and bend it to a template i gave him. I told him i hear they break and not to worry about it if it did, but it didn't and she now has a nice lever for herself, plus the stock one is still in tact.
If you want to bend it, heat it up real well first.
I bent back a stock CBR brake lever that I was sure was going to break.
It was bent from a fall so I had nothing to lose.
Heated it with a small propane (crack type) torch and went at it slowly and patiently.
Don't think I let the lever turn red, just heated up real well in the spot I needed to bend.
That lever is still in service on my friend's bike after more than two years.
Same porous, cast aluminum type lever.
She can either buy a gucci span-adjustable lever from ASV, or break out a couple of big box wrenches and custom bend it to suit her.
I've custom bent many of my Yamaha clutch levers without them breaking (and also straightened them out after a crash).
Just avoid trying to make a sharp bend concentrated at one point.
I'd have a spare lever on hand if this is your first try at it. :banana:
As far as my choice of levers for my WR-250R goes, I'm using the stock clutch and front brake levers from a Yamaha XT-350.
I like the shape of them better - they're a pinch longer and the length and shape allows better feel since I like to position my clutch lever perch and front master cylinder toward the middle of the handlebar as much as possible for more leverage.
Plus, I like the black color. :lol:
Another idea is a magura hydraulic clutch that is adjustable.. its an easier pull too! But pretty expensive
