rubber Piece under gas tank
Build it up with some old innertube or mold up some rtv silicon let it sit overnight I repaired my camaro window side seals 10 years ago [still look stock]
good call. i'd probably cut up an innertube into strips and glue them together with silicone until you get the right thickness. do the bottom 2 layers double wide to wrap the ziptie around and you should be good.
