2005 RMZ450 fork oil question
Personally I don't add a specific amount. I fill the cartridge, bleed the mid-valve and then measure down what would be the equivalent of the distance from the o-ring on the cap, to the o-ring on the floating piston. Then siphon out any excess. Install the compression unit and bleed off the rest of the overfill by stroking the cartridge through.
