How much fork oil?
Inside the damper rod is 193ml/6.52oz. Make sure the damper rod is fully extended. Here's some videos that show how to do it without measuring.
Part three discusses the damper and reassembly of the fork.
Part one:
Part two:
Part three
Edited by rmzpegger
http://mx-tech.com/?id=home
Use the spring generator, type in bike info and it will give you all your specs. MX-Tech sayes: 350cc.
310-395 ml is the adjustment range for the outer chamber according to my OEM manual.
You start with 193 ml for the inner tank (damper). Install piston assy very slowly and screw damper piston assy into the tank. You then push the damper rod all the way in and retract it several times and then dump the excess oil out of the drain holes of the tank before reassembly of the fork tube.
The 350ML or CC depending on how you look at is the lower chamber volume. I think you number for the upper chamber is right.
