06 200xc kickstarter bolt
anyone know if the kickstarter bolt is standard or reverse threads?
standard and should be on with loctite. If it isnt loose dont touch it and the loctite will holc. Once you turn it to check it then you break the bond and need to do it again. Also its common for these bolts to break off after a few removals.
