Starter on 02 400 EXC
Has anyone ever had this problem? I have a new battery and a new starter switch on the handlbar and my starter doesn't work right. When i hit the button it like pauses like no contact and hten finally hits. I have even checked the connection on the starter and it still does this. Is there a possibilty that my starter is bad? How much does a starter cost anyway?
Thanks!
Check and clean all of your chassis grounds. At the battery, sub frame, and motor mounts.
I have heard of people taking the starter motor apart and cleaning the contacts inside and / or replacing the brushes.
What size and brand battery did you get?
Also make sure your valves are adjusted correctly. The automatic decompression is very dependent on valve clearance. Set them using the 1/6 method.
