Bleeding brakes.
Hi there. i have a 124cc chinese pit bike. The front brakes are not working, and i am trying to bleed the fluid through them. I know how to bleed the brakes, but i believe there is a bad connection right after the reservoir. The o rings on the brake line leaving the reservoir are toast, ive tried to put new ones in, but i dont know what size, and they are not sealing properly. Does anyone know where i can get these o rings. The fitting is just letting air into the system, and releasing pressure before it can send brake fluid down the line.
I hate to be the bearer of bad news, but this is just one of many, many, never-ending problems on these cheap, garbage, chinese knock off bikes.
theyre like a cookie, sure they look nice at the start, but give them a day or 2 and they will crumble and turn into shit. literally.
but if you want to continue replacing all its parts, I would recommend buying a whole o-ring kit, or contact the manufacturer...
