2008 kx250f axel
ok guys my axil is stuck and want budge we hit it with a sledge hammer still didnt budge so after i get it out i was wandering if anyone has put grease fiting in the hud and im also thinking bout puting one in the neck of the frame tell me what you think or if you have done it
Sounds like you're going to need new bearings as well. Lesson learned, grease your axles and bearings often.
If you get it out and haven done any damage to the threads shaft etc. You need to take some 2000grit sand paper and smoth that Axel then polish it with mothers or mas.
Then replace your wheel bearings and the inner spacer.
You may want to consider. Replacing the Axel also.
That happened to mine when I purchased it. (used)... I did what Pr1mal said... now she slides smootheeeee.
if it comes down to you cant get it out with out damaging your forks/swingarm then you may need to cut it out. Unfortunatly that pretty much means a new hub also.
