06' & up TE450 EBC 320mm rotor.
Hi Guys.
Anyone get the same kit? The part # is SM6184C, it fits 06 and up.
I am running sm450r 07 rims. The rotor has 6mm countersunk holes! Why would they make a supoermoto race rotor that bolts onto a thinner, larger diameter dirt bike rim??? It makes no sense!
I ordered the Smr 450 07 bolts and to my dismay, they are button head bolts. Will they pass between the rotor and the caliper, or is the caliper far enough away so that this is not a problem?
Should I make new countersunk holes, if so, do they have to be .5mm bigger than 8mm?
Can I just drill them out and use button head bolts?? If so, how should I go about drilling? Use a drill press or free hand? What type of drill bit?
What difficulties did you experience ?
Much appreciated!
Edited by Thumper2010
I have the same kit but they sent the wrong mounting bracket.
What part number is on the back of your bracket?
Dude, thanks for getting back!
My bracket says part # 125.
Was yours the same part #?
What did you end up doing?
