Lean Pilot ???
On decel, (closed throttle) backfires, with blue flames
KOZO PZ28 (PWK clone) MJ:110 PJ:42 2.5 turns out
(Engines Only - TM24/manifold in photo)
PRC built - XR150 stroker
14.3 HP - Dynojet 250i
The bike is set up to run on an indoor gokart track.. www.allsportsgp.com
using only 2nd/3rd gear..
Pic from AllsportsGP...
(see below link)
http://nobalance.com/gallery/v/motorcycles/allsport_030710/DSC_0549.JPG.html
Edited by millwoodva
Classic sign of an air leak or obstructed low speed circuit. I've had low speed ports obstructed by dirt in the fuel. Very difficult to remove, it took compressed air from the venturi side to blow out the dirt.
Has it always done that or did it just start?
Sorry guys.. I just installed the PZ28..
It pulls much harder than the TM24, so it needed the larger bore carb.
Then probably what Chuck said. If the carb was sitting before you put it on, it probably has a clogged pilot. I would check that first.
X3 with Chuck.
However, I had the same lean decel condition with my PWK 28, riching up the needle clip position cured it, For MX!
Also had the same issue with 560SMR, resulted in rich'n the pilot and needle.
It's a new carb..
The intake port is also "blackened"... I'm guessing from backfire..:lol:
.. burnt valve..?:banana:
