Pink Wire mod
Still new and learning about my "new" 450x... I read about the pink wire mod which clipping it takes away the rev limiter.. I am trying to understand the usefulness of this... I find myself at times waiting a bit longer than i should to shift and the power is beyond its peak... What purpose does clipping the wire serve other than putting your engine at risk.. Seems like there isnt much to gain by doing this..
Doesn't take away the rev limit, just raises it. Don't cut the wire, just remove it from the plug and reinsert into the vacant spot on the plug. Try it and see if YOU notice any difference, many say they don't. Because the way the X is tuned your usually shifting way before the limiter, also the stock exhaust baffle and airbox restrictions makes it harder to rev into the limiter.
