Lean Slow Air Jet??
Max rpm 3rd gear.. On decel, (closed throttle) backfires, with blue flames
KOZO PZ28 (PWK clone) MJ:110 PJ:42 2.5 turns out
(Engines Only - TM24/manifold in photo)
Was thinking to try a #35...
PRC built - XR150 stroker
14.3 HP - Dynojet 250i
The bike is set up to run on an indoor gokart track.. www.allsportsgp.com
using only 2nd/3rd gear..
Pic from AllsportsGP...
(see below link)
http://nobalance.com/gallery/v/motorcycles/allsport_030710/DSC_0549.JPG.html
you mean pilot jet? what is the currect air screw setting?
Yes.. as mentioned above: PJ #42.... 2.5 turns out
That does not make sense , if you have a #42 and you feel its lean then why would you want to go to a #35 ? , that would be even leaner !
also check your header gasket and the connection where the header attaches to the muffler , if there is any leak it will backfire as well , so make sure that neither are loose !
I just installed this NEW carb.. so still trying to dial-it-in.
That's what I thought..smaller is leaner, till I read this thread from William1
http://www.thumpertalk.com/forum/showthread.php?t=595711
post #5 "Slow Air Jet.. Richen with smaller jet" looks to be from SUDCO.
Edited by millwoodva
its gonna pop on decel no matter what.thats just life with a pipe that short.
It did not pop with the TM24...
I just installed the PZ28 carb.. pulls much harder now, so it likes the larger bore carb.
Slow air jet works in conjunction with the pilot jet. The idea being is you size the slow air jet to put the pilot jet in a mid range point.
As Eddie says, a pipe that open and short is going to backfire more. The shorter and more open, the more pronounced it will be.
If you richen the pilot circuit a bunch or reduce the straight diameter of the needle to reduce it, your low speed jetting will be too rich. On top of that, hot starts will be tough.
Set your pilot circuit up right, realize the popping is a matter of fact and ignore it.
With a smaller carb, the increase in vacuum on decel does reduce popping some at top end expense.
The intake port is "blacken" from.. I'm assuming, the backfiring as well...
