DRZ400E Head and Base gaskets for DRZ400SM
hello I'm looking to install DRZ400E Head and Base gaskets on my 07 DRZ400SM, When I place my order, is there a specific year DRZ400E i should order???? :lol: please and thank you :banana:
Same for all years.
I've bought cometic several times, good quality and fair price for a set
Only the base gasket is different (single layer as opposed to 3 layer)
Not worth changing unless you have the engine apart already
thanks guys, I'm going to be checking valve adjustment, locktite fixes and mcct why not add the E model gaskets for the extra compression while the tank and seat and what not is off. . . right?
are you planning on replacing the rings and pin locks as well? Ball hone the cyl for good seat on the new rings?
Hoestly,,, just the gasket is a waste of time, money and energy UNLESS you are taking the top end off anyway.. Might as well buy and install a big bore at the same time.. gets you a new piston,, pin, locks, cyl, gaskets.. :banana:
The gaskets will net you at most .2hp, require premium fuel, let alone the additional work Bronco mentioned. Simply not worth in. Get some E or Hotcams cams instead.
