Does cr450f rims fit cr250 -00?
I have found out that cr250 from -02 have same rims as 450f, but will the rims fit a cr250 -00?
You can try going to bike bandit . com, find the part number for either one, then do a search for that part number. When the part comes up, you can hit the "fit bikes" and it will tell you what other bikes the part fits. You can compare the axles, rotor, sprocket, etc if you want to pick it apart.
The 00-01 wheels will fit, but with the 02+ wheel you need to use a 02+ rear rotor since the mounting bolts are different sized.
Thx :banana:
