Bleeder screw
Where is the bleeder screw on wr250x. I am doing my first oil change and seem to cant find it. Why do i have to unscrew it after every oil change. Is it necessary?
It's on the top of the block, facing the rear of the bike. kinda hard to get to. Don't remove it all the way , too hard to get back on, plus oil goes every where. Use a 10mm wrench, back it out a few turns after changing oil and filter, start the engine....when oil starts to ooze out, shut it down and tighten.
http://img246.imageshack.us/img246/8992/jbs00220001kf1.jpg
+1 I don't use that screw. Oil changes have been fine without the hassle of farting around with it.
i really appreciate the tip. I took it out....first mistake..took bout 15 minutes to put it back in. Lesoon learned on that one. I will never take it out again.
That's usually what it takes. One lesson in frustration = screw it the next time. :banana: You won't hurt anything not using that damned thing.
Just crack it loose and make sure a tad seeps out. If it doesn't then it's good to know then
