rebuilding +5mm crank
thinking ahead here.
since the 5mm stroker crank is no longer available from hotrods,will it be possible to rebuild one with their rod kit(since it's a stock lenght rod).
how's the press fit after?
needs to be welded?
needs to be welded?
It's not available from hotrods but there is still stock in ebay and i guess also in some stores.
But i think that the +4mm one is better as you don't need special pistons or spacers.
I have the 5mm one and after 2 special pistons i'm now messing with the spacer.:banana:
You don't have a good mechanic.. he is making better with a drz400sm '05 with Akra + fcrMX39 who has it another guy..!
